Nouveautés dans l'album MG
- JMarc
je craque !
je ne peux plus mettre de photos en ligne, que se soit par l'ancienne methode qui me dit :
Espace disque dépassé
Vous avez un quota d'espace de 1024K, vos fichiers utilisent 20714K, le fait d'ajouter ce fichier vous ferait dépasser votre quota.
ou par la nouvelle methode qui me dit:
20:11:20.812 [INFO] Debug level set to 0
20:11:20.812 [INFO] Current debug output file: C:\DOCUME~1\patricia\LOCALS~1\Temp\jupload_48228_log.txt
20:11:20.828 [WARN] Invalid int value: true, using default value: 0
20:11:20.984 [INFO] JUpload applet, version 3.4.2rc4 [SVN-Rev: 489] (compiled: 07/08/2008 10:56 PM), available at http://jupload.sourceforge.net/
20:11:20.984 [INFO] maxFileSize: 5000000
20:11:21.875 [INFO] JUpload plugin for coppermine version 3.2.2
20:11:53.343 [WARN] L'image 'Z4a.JPG' est trop grosse. Elle sera envoyée sans modification (rotation...)
20:11:55.093 [WARN] L'image 'Z4b.JPG' est trop grosse. Elle sera envoyée sans modification (rotation...)
20:12:03.187 [INFO] Debug level set to 1
20:12:03.187 [INFO] Current debug output file: C:\DOCUME~1\patricia\LOCALS~1\Temp\jupload_48228_log.txt
20:12:03.187 [INFO] JUpload applet, version 3.4.2rc4 [SVN-Rev: 489] (compiled: 07/08/2008 10:56 PM), available at http://jupload.sourceforge.net/
20:12:03.203 [DEBUG] debugLevel: 1 (debugfile: C:\DOCUME~1\patricia\LOCALS~1\Temp\jupload_48228_log.txt)
20:12:03.203 [INFO] maxFileSize: 5000000
20:12:12.343 [ERROR] [wjhk.jupload2.exception.JUploadExceptionUploadFailed] An unknown error occurs during upload. (An unknown error occurs during upload.)
20:12:12.375 wjhk.jupload2.exception.JUploadExceptionUploadFailed: An unknown error occurs during upload.
20:12:12.375 at wjhk.jupload2.policies.DefaultUploadPolicy.checkUploadSuccess(DefaultUploadPolicy.java:625)
20:12:12.375 at wjhk.jupload2.upload.DefaultFileUploadThread.doUpload(DefaultFileUploadThread.java:761)
20:12:12.375 at wjhk.jupload2.upload.DefaultFileUploadThread.run(DefaultFileUploadThread.java:517)
20:12:24.343 [ERROR] [java.lang.NullPointerException] null (Une erreur est survenue durant la gestion des logs (dataout.close))
20:12:24.343 java.lang.NullPointerException
20:12:24.343 at wjhk.jupload2.policies.DefaultUploadPolicy.sendDebugInformation(DefaultUploadPolicy.java:1164)
20:12:24.343 at wjhk.jupload2.upload.DefaultFileUploadThread.run(DefaultFileUploadThread.java:573)
20:12:25.484 [ERROR] [java.lang.NullPointerException] null (Une erreur est survenue durant la gestion des logs (sock.close))
20:12:25.484 java.lang.NullPointerException
20:12:25.484 at wjhk.jupload2.policies.DefaultUploadPolicy.sendDebugInformation(DefaultUploadPolicy.java:1179)
20:12:25.484 at wjhk.jupload2.upload.DefaultFileUploadThread.run(DefaultFileUploadThread.java:573)
20:12:26.703 [ERROR] [wjhk.jupload2.exception.JUploadIOException] Trying to get the byte array of a on non-closed ByteArrayEncoded (Could not send debug information)
20:12:26.718 wjhk.jupload2.exception.JUploadIOException: Trying to get the byte array of a on non-closed ByteArrayEncoded
20:12:26.718 at wjhk.jupload2.upload.helper.ByteArrayEncoderHTTP.getString(ByteArrayEncoderHTTP.java:305)
20:12:26.718 at wjhk.jupload2.policies.DefaultUploadPolicy.sendDebugInformation(DefaultUploadPolicy.java:1185)
20:12:26.718 at wjhk.jupload2.upload.DefaultFileUploadThread.run(DefaultFileUploadThread.java:573)
20:12:26.796 [WARN] CoppermineUploadPolicy.afterUpload: No file were uploaded! (0)
restons polis !
pourquoi tant de haine ?
restons polis !
- yellowcitron
- JMarc
JMarc a écrit :je craque !
restons polis !
president ! au secours !
je suis obligé de passer par imageshack pour mettre des photos !
ALAIN33
- Serie speciale : MGF 75TH N° 1412 - année de production 23/04/1999
Bonsoir à tous
Au risque d'apparaitre pour un nain, et je le suis surement, il faudrait qu'un expert, il y en a sur le forum, écrive une procédure trés trés claire, ligne à ligne, de ce qu'il y à lieu de faire pour définir un album, mettre des photos dans cet album ( à l'unité ou en quantité, rapatrier ces photos dans un post
Je n'arrive pas à mettre des photos dans l'abum, j'en ai un grand nombre faites lors des rassemblements de BORDEAUX Base sous marine des 29/06 et27/07/2008.
Et surtout de grace pas de commentaires du genre, mais c'est facile
Merci beaucoup chers experts
Salutations
ALAIN
Salutations
ALAIN
Renou-Invité
Les informaticiens ( les développeurs )sont des gens bizares... Pour compenser l'effritement du marché, ils mettent au point des nouvelles solutions qui consomment et font vendre de plus en plus de ressources pour faire la même chose qu'avant, mais c'est beau, c'est graphique, on clique et même le profane croît s'y connaître. Depuis 5 ans, pour charger les PC et servers ils nous font le coup de JAVA. Et ça marche, désormais il faut 1Gb de mémoire et 4Ghz de cadence CPU de PC. On croit rêver, mais les benches ( test puissance ) sont attérants. A +
