Entraxe roue de Midget
- année : 1978
- année : 1978
Voici le debut du sujet sur le forum du MGOC.
Thread: Question from France
D'abord, ma question:
DAVID BALKWILL
Manchester
d.balkwill@mmu.ac.uk
Posted 21 May 2008 at 17:52:42 UK time
Well, indirectly from France...
I was reading their very active forum, and spotted theis thread from someone looking for Cosmics to fit a Rochdale which has some very rusty looking Rostyles (Midget size) at the moment.
http://www2.mgcontact.eu/phpBB2/viewtopic.php?t=8996
Can anyone help him out?
I'll happily translate if you get stuck.
Many merci's
David 78 B GT
Et voici la premiere reponse 30 minutes plus tard :
Deborah Evans
Here and There
Posted 21 May 2008 at 18:24:09 UK time
What sort of Cosmics?
I have a set of Cosmic MkI alloys that came off my G15.
13" x 4.5J 4" PCD
Il y en a quatre, d'ou les deux photos que j'ai mis dans les albums hier soir.
Je n'a pas son adresse mail (a Deborah), mais je vais lui dire que tu aimerais connaitre son prix, et puis si vous m'emvoyez vos mails tous les deux on doit pouvoir s'entendre.
Je ne sais pas ou elle habite, mais il y a des services d'expedition qui doivent travailler entre ici et la bas pour les jantes. Les pneus sont visiblement morts.
David
DAVID BALKWILL
Manchester
Many merci's
David 78 B GT
Deborah Evans
Here and There
13" x 4.5J 4" PCD
David
- année : 1978
Voici la reponse de Deborah.
J'ai son adresse mail pour la suite.
David,
The Cosmics need to be re-furbished, nothing a quick bead blasting and paint won't sort out. They are a set of 4 plus a spare, but there are only 4 centre caps.
They are down in Winchester atm so it will take me a week or two to get down there and dismount the old tyres.
I'm looking for 250 Euros plus shipping.
I'll EMail you my EMail address.
Your friend may want to join this forum (what used to be 'Cottage Classics'), since there is a lot of knowledge there about low production GRP cars (indeed my current Ginetta G15 build is being recorded there):
http://www.ginettaheritage.co.uk/phpbb/
David,
Je pense que c'est le sujet sur le Ginetta de Deborah : http://www.ginettaheritage.co.uk/phpbb/ ... .php?t=326
- année : 1978
Rien dans la boite ce matin.calex_fr a écrit :Super, je t'envoie mon adresse Email.
Merci !
Encore un essai STP.
- année : 1978
FRU12D built in 1965, registered March 66, Ford 1500GT engine, box and rear axle, Triumph Spitfire front suspension, with Ford drilled hubs, running 5 1/2/6" Ford rims. Apparently it has a heavy duty shell, with built in roll cage
http://s261.photobucket.com/albums/ii71 ... FRU12D.jpg
http://s261.photobucket.com/albums/ii71 ... 7small.jpg
http://i204.photobucket.com/albums/bb20 ... FRU12D.jpg
- année : 1978
- année : 1978
- année : 1978
J'ai envoyé un message, mais Il faut simplement lui poser la question.
Pas mal de messages récents là
http://www.ginettaheritage.co.uk/phpbb/ ... a&start=90
David
David
je recherche des sièges exactement comme ceux-ci.
On en voit souvent sur les anglaises de compétition, mais je suis incapable d'en trouver !
Vous savez qui les vends ?
http://picasaweb.google.com/calexfr/Age ... 0029435666
- année : 1978
Le propriétaire doit savoir puisque le siège a l'air neuf, et les deux ne sont pas le même.
J'ai cherché un moment via Google.
Une maison qui peut répondre peut-être http://www.allonwhite.co.uk/bespoke-coach-trimming.asp
Et ces gens la pour Jaguar XK 120 etc
http://www.guybroad.co.uk/gallery/index.cfm?id=11
Sur une MG en Australie http://www.flickr.com/photos/91919735@N ... 035863634/
Version Spartiate en bois... (au milieu de la page)http://www.prewarcar.co.uk/previous_fea ... ecord=1124
Plus cossu dans une réplique de Cobra
http://www.kitcarmag.com/featuredvehicl ... to_02.html
Bonjour David, Debs a lu mon MP sur Ginetta Heritage, mais pas de réponse... :-(David Balkwill a écrit :J'ai envoyé un message, mais Il faut simplement lui poser la question.
David
Bonsoir à tous,
je vais vous raconter une petite histoire.
J'ai trouvé 4 jantes Cosmic de Ginetta G15 chez le spécialiste de la marque en Angleterre. Il me les vends mais je dois m'occuper du transport. Aucun problème, j'organise cela avec Interparcel que je paye et que je commandite pour la collection et le transport par DHL jusque chez moi.
Collection le 6 décembre, je ne m'inquiète pas, le 6 étant un vendredi, le colis devant m'arriver sous 5 jours je l'attendais pour le 14. Le 16 je contacte mon fournisseur, une partie du colis lui était revenue car il avait fait un seul colis avec 2 boites de 2 jantes (vous savez les jantes neuves sont livrées par deux et il a pris 2 cartons de minilites pour en faire qu'un en les scotchant) et que cela s'était détaché. Bref il renvoit le second, car seul lui savait où l'envoyer, eux savaient juste où ils avaient collecté ce colis....
Depuis tous les jours j'attends et je contacte Interparcel pour avoir des nouvelles de mon colis, car en plus impossible de le tracker avec le N° qu'ils m'ont fournis lors de la commande....
Lundi sans réponse d'Interparcel, mon fournisseur les appelle et leur explique, le colis serait en Allemagne....
Hier le 23 je reçois 1 colis qui serait parti le 17 !
On voit bien dessus le scotch qui était entre les deux cartons, il y a même du scotch DHL !
Par contre le second, disparu !
Je ne le recevrai surement jamais, à moins d'un miracle de Noël
