Fillet anti-remous sur une MGF
jma
charly
jma
Matt
bon alors tu es sur quelle région? que je puisse voir le filetMANGA a écrit :Pas eu le temps d'en faire j'etais deborde au travail , mais si je vend un filet c'est qu'il est en bon etat...!
www.mgfcentre.com
en fabrique un pas chere vous en pensez quoi ?
celui la me plais bien...reste à savoir si il se replit.
voici le déscriptif :
Code : Tout sélectionner
The NEW WINDSTOP with your safety in mind
This composite material will not break from a strike with a hammer, elegantly demonstrated by Carl.
We are putting your safety first so you can rest assure that the item preventing the wind into your cockpit is a safe as it gets. The way in which it mounts to the base plate prevents any movement even at 100 mph. With a smoked tint , modern shape and anodised base plate, this windstop will give any age of car a stylish look inside and out.
The most important benefit is that it works! Fits in minutes. No Drilling required.
Also included is a carry case that fits smartly in to the boot and velcros to the side so not taking up any room, for when you would like to remove it completely.
£97+vat for a limited time
Logo is for promotion purposes only, the final
product will have a logo of only 1" square
Utilisateurs parcourant ce forum : Baidu [Spider] et 4 invités
